Forum: Old versions
Topic: Help with Hercules MK2
I just bought the console hercules mk2 with virtual Dj few weeks ago. Now i need help about two things.
First: Why can't record my mixes in mp3.
2nd: Can someone explain me what are the things I have to do and what are the wires I need if i wanna plug my consoe along with my computer in a sound system
geposted Sun 29 Apr 07 @ 6:48 pm
1:
http://www.free-codecs.com/download/Lame_Encoder.htm
download and extract this to
C:/programfiles/virtualdj
2.
each line represents a double phono cable
if you wish to use turntables as well hook up the inputs 1/2 and 3/4 if not ignore this
should you wish to use an external mixer connect outputs 1/2 and 3/4 to the mixer then the master out of the mixer to the amp .
choose external mixer on vdj , and on the herc console
if you wish just to use the mk2 use a double phono cable to connect to your amp.
Regards
Simon
allright thx simon really appreciate
any time :)
