Forum: Old versions
Topic: help i cant use virtual dj wirh audigy 2
hi
i buy the data code vinils and download the trial version of virtual dj but i cant use two disc. only one conect to line in, and the other disc no recognizes the program please help for purchase the full version if this works
tanks
geposted Tue 01 May 07 @ 8:56 pm
You'll obviusly need the full version (not DEMO version) to use 2 timecoded vinyls, which can be obtained here > http://www.virtualdj.com/purchase/
Besides the obvius advantage of a full version, you'll recieve free updates, community and staff support, skin downloads, sample and effects downloads etc..
Hope to see you soon!
but you can asecurate if i buy the full version i can use two turneables with my sound card audio audigy 2, becouse i´m not sure if this sound card is correct or if my problem is only of configuration
If it's ordinary Audigy 2 than you have only one input so there is your problem. You need 2 stereo inputs on your sound card like Hercules Mk2, Maya 44 or ESI U46DJ.
The demo have all functions like Pro version just it is limited to 20 days of usage.
