instead of plugging in ur turntables to the outputs on ur soundcard, would it work if i just plug them in to my mixer? will i get the same results?
geposted Wed 02 May 07 @ 4:32 am
no, not if you want to use VDJ. The Time Coded Vinyls send a signal to the computer, thru the ASIO soundcard. You can connect the computer to the mixer, with the headphone jack, or speaker jack. But if you want to use VDJ you need some other connection, not just the direct connection from player to mixer. If you try to connect directly using the TCVs you will hear a very odd sound....
geposted Wed 02 May 07 @ 4:42 am
okay thanks man.
geposted Wed 02 May 07 @ 4:53 am
