Forum: Old versions
Topic: mac questions
hey guys i have a mac computer and i want to go with virtual. I have a few questions before i do.
1. Is virtual dj out of the beta mode for mac and is it good to go.
2. Can i use the gigaport ag audio interface to connect my external mixer
3. can i use the dac 3 controller if not what controller do i have to use.
Please help me out i want to do this ASAP
geposted Wed 02 May 07 @ 11:19 pm
Well its out of Beta. Its stable. Has a few issue that are noted in the Bug report forum.
If the gigaport AG audio interface is a USB sound card, it should work.
I dont think the DAC 3 is supported in this build as this option is greyed out in the current release.
IF you use the Hercules MK2 it works good.
IF you dont have a controller yet, wait till mid may as the Numark total control is to be release. Its a pro style controller and I like the look and feel of it.
Hope this helps
