Forum: Old versions
Topic: Any skins for MAC yet?
I just got the Virtual Vinyl package and have been toying with Cue. Seems solid so far, but im yearning for a better skin for videos. Something with large screens for vid mixing similar to the one with three screens in line, but for Mac.
Any time frame for Mac skins? Or is this something I should look into attempting to create myself?
Thanks, Charlie Five
www.myspace.com/djcharliefive
www.visualizechicago
geposted Thu 03 May 07 @ 6:11 am
as said before
the skins are in the same format so if you have a pc you can copy these skin zips across
or you will need to wait for the mac skins to be repackaged on the website, happening very soon
Charlie,
If you can extract the exe files on a pc, you can just take the .zip file from the skins folder and drop this in the skins folder on your Mac...
jchiar,
Where exactly? /Applications? /Users?
dj korn if you using the mac version please add your serial as there is no demo .
hope to see you with us soon
That's Sky's polite way of saying, "Just say no to crack... cracked software that is".
- VT ConQuest
(Visual Turntablist)
