Forum: Old versions
Topic: Sync / Pitch Resets
For some very odd reason, after I sync a song by clicking the "sync" button, the pitch resets back to 0% within seconds. The odd part is... it was working fine 30 minutes ago, where a synced song would stay synced. I am not sure what I did to change the settings.
I double checked all the options, Auto Pitch-Match and Auto Pitch-Reset are both disabled.
Any ideas?
geposted Sat 05 May 07 @ 7:24 am
I forgot to mention, I am using TCCDs. But I don't see how that should make much of a difference because sync was holding before.
bump
Did you activated some option in Timecode settings? If not, reinstall VDJ and clean Registry key as well.
yup, ended up reinstalling it. still not sure what the problem was. thanks anyways.
So it is working now? Glad you sorted it out!
