Forum: Old versions
Topic: Sync / Pitch Resets
For some very odd reason, after I sync a song by clicking the "sync" button, the pitch resets back to 0% within seconds. The odd part is... it was working fine 30 minutes ago, where a synced song would stay synced. I am not sure what I did to change the settings.
I double checked all the options, Auto Pitch-Match and Auto Pitch-Reset are both disabled.
Any ideas?
geposted Sat 05 May 07 @ 7:24 am
I forgot to mention, I am using TCCDs. But I don't see how that should make much of a difference because sync was holding before.
geposted Sat 05 May 07 @ 9:09 am
bump
geposted Sun 06 May 07 @ 12:13 pm
DJ-ALFPRO InfinityModeratorMember since 2005
Did you activated some option in Timecode settings? If not, reinstall VDJ and clean Registry key as well.
geposted Sun 06 May 07 @ 4:38 pm
yup, ended up reinstalling it. still not sure what the problem was. thanks anyways.
geposted Mon 07 May 07 @ 12:40 am
So it is working now? Glad you sorted it out!
geposted Mon 07 May 07 @ 11:42 am
