Forum: Old versions
Topic: DJ MIXSTATION 3
I just bought it and I can't play my music. What am I doing wrong or have to do? The demo worked fine. I hit desktop and my media player files showed up in the box but they had a yellow question mark by the cd icon which I understand means not loaded. How do I load my files?
geposted Sat 05 May 07 @ 11:35 pm
so youv dragged it onto a deck hit play and nothing happened yes?
try a reinstall
I did that and it still doesn't work.
ok are they .mp3?
No, but the case said it didn't have to be. They are wav. files.
ok that should be fine . what sound config options do you have ?
Primary sound driver or conexant hd audio output. Then below that two choices that have a box to check, software 3d or output 7.1
Since my cd icons have that yellow question mark that means my songs aren't loaded, how do I load them?
the question mark meens they havent been analized yet
right click on local datbase and press scan hardrive
i suggest you aslo make a support ticket explaining your difficulty playing tracks
here
contact
