Forum: Old versions
Topic: VIRTUAL DJ 4 BROADCASTING **PLEASE HELP ME
I USE VIRTUAL DJ 4.0, THEN TO BROADCAST. IS THERE A WAY TO GET IT LISTED IN THE SHOUTCAST SERVERS?
geposted Sun 06 May 07 @ 9:44 am
sbangsPRO InfinityMember since 2004
yes if you stream to an external shoutcast host,
geposted Sun 06 May 07 @ 11:31 am
I STREAM IT! IT WON'T SHOW UP IN THE DIRECTORY..??? WHY NOT?
geposted Mon 07 May 07 @ 7:16 am
if you use vdj as a server it wont show up in the list
you need to stream to another server which is listed in the shoutcast lists.
geposted Mon 07 May 07 @ 1:47 pm
OK NOW I'M CONFUSED. HOW DO I DO THAT?
geposted Tue 08 May 07 @ 4:32 am
geposted Tue 08 May 07 @ 10:53 am
i do it through severroom. isn't their an easy way?
geposted Wed 09 May 07 @ 5:17 am
when you use virtual dj as a server , it wont be listed in shoutcast so im afraid not.
to get listed in the radio station directory you need to connect to the shoutcast server software
geposted Wed 09 May 07 @ 10:34 am
Is there a way to make virtual dj stream through winamp?
geposted Fri 11 May 07 @ 1:27 am
ciocePRO InfinityMember since 2004
geposted Fri 11 May 07 @ 12:15 pm
I have a shoutcast already setup....But when you go through shoutcast via virtual dj. It will not put you in the shoutcast directory, and it doesn't let you post your instant messenger id's so people can message you. Can I broadcast out of my virtual dj and somehow get winamp to play it?
geposted Mon 14 May 07 @ 4:21 am
ok i repeat :) on virtual dj
1. set to external server
and choose the ip to 127.0.0.1
port 8001
password your shoutcast server password
2 .hit connect
3.now on the server software from nulsoft
you will see a new connection and it should be listed in shoutcast directory
geposted Mon 14 May 07 @ 10:52 am
