Forum: Old versions
Topic: IBM Laptop
I'm looking for a laptop to use with my dj console mk2 (PC) And i've found a IBM R40 with a Intel M 1.4 Ghz processor. The problem is that in the requirements it says that you at least got to have a Inte Pentium III processor wth at least 800Mhz. The difference between this specifications is that the IBM has a Intel M processor instead of a Pentium III processor.
So my question is. Can you use this laptop with the Dj console?
geposted Sun 06 May 07 @ 2:46 pm
Yes, because this Mobile processor has more cache than Pentium 3, 1Mb or even 2, depending of the model. You just need to disable all power saving options in Bios like Speedstep and similar which is designed to save battery life but cuts down the performance.
