Forum: Old versions
Topic: Author does not show, files from Itunes
Hi all,
I am a new user and I am trying to get the music database to work. I copied all the songs from my Itunes library (on another computer, copied via an external hard drive) but when I add them to the VDJ database the Author field is empty. Why is that? As a read the manual, this should work default?
Or is there some special way the Itunes library should be set?
Regards,
geposted Sun 06 May 07 @ 9:50 pm
You will need to rename all your itunes files to: artist - songtitle.mp3. If you have Music Match pro, it can rename them all at once from the tag info
Hi and thanks for your answer,
Is Music Match pro a part of Itunes or a separate software? If separate, where do I get it?
