I installed vista, working fine except it won't let me keep the drivers I want. Evrytime I reboot it re-installs the driver it thinks is best. What the bamba clot?
Let me elaborate. I installed my old graphics card driver(xp) cause the one vista installs only goes upto 1024x768. Problem is my laptop's res. is 1280x800, so it's blurry. When I manually install my old driver it works fine on 1280x800(picture is perfect) as long as I don't reboot. Once I reboot, it'll automatically update the driver to the latest which I don't want. Anyone know of a way to stop this. I've been googling, i'm not the only one with a similar problem with Vista & drivers.
Skyfxl, here we go.
Skyfxl, here we go.
geposted Mon 07 May 07 @ 7:47 pm
let me get this straight you are trying to install xp drivers on a vista machine, and you are wondering why they don't work? I'd be going to the graphics card makers site and checking for a vista driver or the laptop makers site and doing the same.
If you don't want auto update on then turn it off
Go into the Control Panel, Double Click on Automatic Updates, and uncheck the box that says "keep my computer up to date..."
geposted Mon 07 May 07 @ 8:00 pm
C'mon this is not what it's about.
I did all that, it's not about installing an xp driver, It's about vista installing the drivers it wants, isn't there a way to stop it. Like a service that can be turned off or something.
It also happens if I install a slightly older vista driver, it'll automatically install what it thinks is best.
It's not about Automatic updates. It happens even if there's no access to the internet.
Do you honestly think I don't know about automatic updates? Read the first post.
Basically my problem is that Vista won't ask for my consent when installing new drivers, it does it automatically upon rebooting. Somehow it's a good thing but in a way it's kind of annoying.
geposted Mon 07 May 07 @ 8:08 pm
Control Panel > System and Maintenance > System > Advanced system settings > Hardware tab > Windows Update Driver Settings button >
did you try that?
did you try that?
geposted Mon 07 May 07 @ 8:31 pm
No, I'll try when I get home, I'm still @ work. Don't think so though. There're numerous posts about this problem on google. Thanks.
geposted Mon 07 May 07 @ 8:43 pm
Start > Run > cmd > format C: > Y > Reboot > Install Windows XP
Worked for me :D
Worked for me :D
geposted Mon 07 May 07 @ 9:02 pm
LOL that's a good one!
Anyway, Vista does have problems with drivers as XP once did, manufacturers are to blame for this.
And yes, some of XP drivers can be used on Vista ;)
geposted Mon 07 May 07 @ 9:08 pm
Man, I can't go back to XP. I've already corrupted my head. It'd be like going back to VDJ 3.4. Can you imagine? Trust me I'll find a way. I just need time alone with her.
geposted Mon 07 May 07 @ 9:40 pm
why would ask a question you already knew the answer too?
geposted Mon 07 May 07 @ 11:06 pm
What answer? What's your problem man? & just to let you know, your solution didn't work it only applies to windows update.
geposted Tue 08 May 07 @ 12:35 am
I have no problem other then trying to help you and you keep saying you already have the answer already. Have you checked for updated \"vista\" drivers?
there is always this for ati
http://www.driverheaven.net/modtool/
and this for nvidia
http://laptopvideo2go.com/drivers
and this for nvidia
geposted Tue 08 May 07 @ 4:11 am
A little respect man, we are trying to help ya. And you expect help and you didn't even write down which Video card you have ;)
Anyways, give me exactly your Laptop/PC model and I will try to find the best driver on the Internet for you.
Regards
geposted Tue 08 May 07 @ 9:32 am
About the respect thing, i'm just gonna keep quiet.
Why would you ask a question you already have an answer to? <Does that seem fine Alf?
But you know what maybe it's cause of the way I had my topic posted. Vista shit. It was changed to Vista issue. That I apologise for. Anyway,
I changed the info on the XP drivers & made Vista think they're the latest drivers so they work. Anyway here's the video card type. If you find vista drivers for that card, you are a genius or maybe you made them. Cheap Intel/intergrated card. Intel® 82852/82855 Graphics Controller Family.
The laptop is a Gateway 7330gz <That's the one with the driver problem.
I also can't find the vista audio drivers for this same laptop. Conexant AC97.
geposted Tue 08 May 07 @ 3:39 pm
geposted Tue 08 May 07 @ 5:23 pm
Very nice list of drivers. I've saved it for future use.
I opened the old xp driver with notepad, erased one letter, saved it, put the letter back in & saved it. Now it says modified on 5/08/07. Fooled Vista. It thinks this is the latest driver. In a way I can claim i'm smatter than Bill Gates. :D
geposted Wed 09 May 07 @ 4:53 pm
VDJ works very well with Vista on my end. TCV use for hours with cpu usage hardly hitting 20%.
New install & I didn't even touch the performance configurations in VDJ. I'm using the SL1 box & all I changed was auto on the buffer setting. It played very very very very well. Good Job Team.
geposted Tue 22 May 07 @ 6:29 pm
