I have a maya44 soundcard but i dont have the asio software for it anybody have solutions? i know i can download it but i will need the code or the key to use the full version of it where can i get that?
geposted Tue 08 May 07 @ 12:12 am
Thats something thats been troubling me lately too. There seems to be 2 versions of the driver, one is the basic that comes with the software (no code/key needed) or it seems you can but a fancier version with more features for 60 Euros.
I'm using the basic one, maybe the 60 Euro one will perform better, does anyone know?
Maya Asio XP
http://www.audiotrak.net/atbbs/view.php?id=driver&page=1&sn1=&divpage=1&category=11&sn=off&ss=on&sc=off&select_arrange=headnum&desc=asc&no=58/
Maya Asio Vista
http://85.25.144.200/download/ESI/MAYA44_USB/MAYA44_USB-v2_85.zip
Gary
Maya Asio XP
Maya Asio Vista
Gary
geposted Tue 08 May 07 @ 12:21 am
becarefull with the one for vista i try it on a xp pc and gave me problem
geposted Tue 08 May 07 @ 12:46 am
Why would you try a vista driver on XP? Was you bored? lol
geposted Tue 08 May 07 @ 12:48 am
lol i think so lol, have you try traktor 3 i'm having some problem with it won't see all the ch on my maya ex usb sound card
geposted Tue 08 May 07 @ 12:52 am
how or where do i get the code to unlock it?
geposted Tue 08 May 07 @ 12:58 am
unlock what ?
geposted Tue 08 May 07 @ 1:02 am
Download the one you want from the links above. You won't need a code.
And as for Tractor, i haven't got a clue. You'll have to wait for someone else on that one Phil.
Gary
what do u mean tractor i have cue
geposted Tue 08 May 07 @ 1:14 am
You have to read these things! I was talking to Phil about Tractor, he asked about it and i said i couldn't help him.
All the info you need for the maya asio driver is above. No key or unlocking needed :)
Gary
geposted Tue 08 May 07 @ 1:17 am
o my bad thanks
geposted Tue 08 May 07 @ 1:18 am
thanks GaryBr
geposted Tue 08 May 07 @ 1:20 am
that link did'nt work it says error 0*00008
geposted Tue 08 May 07 @ 1:37 am
I just tried them both, and they work fine for me. The drivers are available on the manufactures website too.
Maybe someone else can verify if those links work ok?
Gary
Gary
geposted Tue 08 May 07 @ 1:44 am
Gary
Gary
Both links work fine and are the correct links for what was asked. Also, the info given about the XP drivers is true as well -- you don't need a key code for those drivers.
cstoll
geposted Tue 08 May 07 @ 1:45 am
ok thanks i got everything working.
geposted Tue 08 May 07 @ 2:12 am
