Forum: Old versions
Topic: what should i get
With all the problems with sound cards i guess its a good thing that i found u all before i just went out and bout one. I still running a ole 32 bit sys. gigabyte 8E and a 3.2ghz p4, 4-160gig ide drives, 1gig ddr2 800. But the intergrated audio is 7.1 surround sound.
Right now im just doing standered track by track on cd by hand and im tired of the work out.
The pc is up to the job but dont think the audio is, and since im in the midwest with a bunch of country folksand there not into the beat match and all the bells and whisles ( but I am) but dont know a thing about all that.
Was looking at vdjpro and a rack mount controller (dac2) but think i might just upgrade now for video in the future(dac3).
Would also like to incorperate the lightshow into it so that one less thing that i have to do manually
geposted Tue 08 May 07 @ 4:47 am
So what is your question here? You will need some better sound card for better sound/results, Sound Blaster Live USB, Audigy, and Maya and ESI U46 DJ for TCV use.
