Forum: Old versions
Topic: mac book, vdj and dac 2
i'm going to buy a mac book but i'm not sure if my DAC2 will work on my new mac. i also have a gigport sound card. is this all compatable. can you help me
thank you.
geposted Wed 09 May 07 @ 3:38 am
jchiarPRO InfinityMember since 2005
In the current build the DAC2 is Greyed out so I dont think its fully supported at this current BUILD.
geposted Wed 09 May 07 @ 5:08 pm
should i just buy a pc laptop?
geposted Wed 09 May 07 @ 9:29 pm
sbangsPRO InfinityMember since 2004
its comming soon:)
geposted Wed 09 May 07 @ 9:36 pm
See.. Its support is coming soon :)
And No , buy a MAC book.
It can run win vista and the pc version in the mean time 100% if you find the mac version not suitible enough for what you need, You have a alot of videos?
The gigaport should work fine.
geposted Wed 09 May 07 @ 10:06 pm
not yet but i will have some soon. so i can run a win version of vdj on a mac? if my mac version doesn't support my dac2?
geposted Wed 09 May 07 @ 10:40 pm
you can use bootcamp to run windows on a mac yes.
its quite easy to learn but
if you feel unsure about using it perhaps a windows laptop is a good bet for you
geposted Wed 09 May 07 @ 10:50 pm
i just wanted to know, when the DAC 3 support will be available for Mac? i want to use VDJ at a gig on June 9th and i need to test everything before the end of this month. thanks for your support guys.
geposted Tue 15 May 07 @ 7:06 am
please dont triple post the same question in many existing threads , i recomend you make a new post for this issue its more likey to be seen.
geposted Tue 15 May 07 @ 10:20 am
Well SKYFX? you saw my post why dont you answer the question? its a simple question and next time i will make its own thread. i actually have if you look in the forum. but you havent asnwered the question.
geposted Wed 16 May 07 @ 11:50 am
as i say it it is possible to be added to the 4.4 release.
geposted Wed 16 May 07 @ 12:19 pm
Yeah! 4.4 :)
geposted Wed 16 May 07 @ 2:54 pm
