Forum: Old versions
Topic: Sooooo......
d-v-intPRO InfinityMember since 2004
We all have lots of issues with the new Mac version of VDJ, this was always going to happen as its the 1st release. So for the next upgrade please list in order of importance what you want fixed in VDJ. Don't turn it into a big discussion please just 3 simple things you want done so that Atomix can prioritise.
I'm sure you'll all know whats going to be top of my list.
1. FULL cross platform midi suppport (esp for reciving data so that jogs work)
2. That the search function works in the browser & also that ID3 info displays properly (only displays song names atm for me anyway).
3. That VDJ loads up songs faster and matches the speed of VDJ on PC.
geposted Wed 09 May 07 @ 1:31 pm
1 - That the search function works in the browser
2 - Timecode support for soundcards other then the virtual vinyl sound card
3 - Fix the video output doesn't have artifacts
geposted Thu 10 May 07 @ 2:20 am
k_onePRO InfinityMember since 2006
1. Working search brower which doesn't crash the software. Wiith FULL ID3 Tag support!!!!!!(A MUST)
2. Preventing corrupt files from shutting down the software(It should just read "error" in stead)
3. Fixing the iCDX platter/scratch algorithem to work smoother. (iCDX on PC works perfect, iCDX on MAC sounds terrible on scrathing)
geposted Thu 10 May 07 @ 11:41 pm
djcel wrote :
If you still have some files which shuts down the software, please send them to xxxx@xxxx or upload them somewhere and give here the link.
Thank you by advance
The problem is that the shut-down occours when analyzing my itunes folder, which at the moment holds about 2400 tracks, and I have no clue on how to figure out which specific file is causing the shut-down.
Any input on how to do this? (And NO, loading each and everyone of the tracks is certainly not an option.Unless your happy with getting the result around christmas 2009)
geposted Mon 14 May 07 @ 12:22 am
