Forum: Old versions
Topic: DAC-3 jog wheels
Can anyone tell me how to disable the scratch feature on the DAC-3 jog wheels with CUE . I tried hitting CP and match buttons as i read in another thread but it did not work.
Thanks, Alex
geposted Thu 10 May 07 @ 3:05 am
You need to be using my custom DAC-3 mapper to be able to do this:
http://www.virtualdj.com/addons/download.html?addon_id=2401
With my mapper, the jogwheel by default will scratch when paused and fine pitch bend when the song is playing. You can toggle scratch on/off permanently by pressing CP+MATCH.
Please see the DAC3Mapper.txt file (Included in the above download) for full details on how to install and use the DAC-3 mapper.
Thank you much.
