Forum: Old versions
Topic: task bar
is there a way to keep the task bar at the bottom off the screen instead of ctrl-alt-del every time.
geposted Thu 10 May 07 @ 3:09 am
yes, you can just minimize it and it will sit in your task bar
choose keep taskbar ontop of other windows on taskbar properties.
