Check this image to see my problem: http://i7.tinypic.com/67ytjlg.gif (semi-translated to english)
I can control playback and volume controls for all my soundcards but Hercules DJ Console Mk2 I can't control any recording fader.
geposted Fri 11 May 07 @ 1:39 pm
Go in Control Panel/Sounds and select MK2 as a recording device to be default.
geposted Fri 11 May 07 @ 4:22 pm
If you refer to this control panel section
I did it and still none recording fader appeared (you can see grayed the Volume control in this last caption)
geposted Fri 11 May 07 @ 6:21 pm
Well something is wrong for sure, try reinstalling drivers for MK2 and try it than.
geposted Sat 12 May 07 @ 5:13 pm
Where are my other post about my username's change and other issues?
geposted Sun 20 May 07 @ 12:15 pm
I've reinstalled drivers (uninstalling them previously and restarting) and I have same problem.
geposted Sun 20 May 07 @ 12:32 pm
http://www.virtualdj.com/forums/70449/PC_Version_Technical_Support/The_autochanged_user_to_ROCK123___.html
it still on the forum.. for this u have to contact e-support
geposted Sun 20 May 07 @ 12:33 pm
try to do system restore or roll back drivers
geposted Sun 20 May 07 @ 12:35 pm
Thanks but I did it and still same problem.
Thanks for help me about ROCK123 (me).
geposted Sun 20 May 07 @ 12:59 pm
Some news about this issue? Impossible to solve it atm for me and technical support does nothing for me :(
geposted Mon 18 Jun 07 @ 12:48 pm
