i mean rapid evolution
ya know you can dl it w/o an installer .... ????? usually you just download and install but hey let's be different
i want that 15 minutes of my life BACK
next when i run import it only imports some of my files and i can't tell for sure which ....had a lot of promo's in it so looks like my promo only file but it should have imported the entire music folder
also track name and artist aren't separate columns ????????
it started out at rockbottom so i thought but it just gets worse
also it hangs in both xp home and xp mce .......????? can't recommend this
what is another standalone database ??? if it had an INSTALLER and was reasonably easy to use, those seem like low hurdles ...........
geposted Sat 12 May 07 @ 5:01 pm
Hey chuck - why not post here - http://www.mixshare.com/cgi-bin/yabb2/YaBB.pl
That's the forum for Rapid Evolution - MixShare
geposted Sat 12 May 07 @ 5:32 pm
i wanted to warn people here that it seems like a lousy database
geposted Sat 12 May 07 @ 5:42 pm
since the database is so important and since i want to use it so much even when not using either of my software players ( don't have to run the ext hd and soundcard(s) ) i thought i would check out RE ......
hoping that a standalone would be great esp since databases at least the ones in the player software seem to be easily lost/ corrupted .......
we are just talking about importing text aren't we ???
very disappointed w/ RE .....since i have 2 existing db's if i can just import either into a standalone i'll be very pleased w/ that
geposted Sat 12 May 07 @ 5:58 pm
