Forum: Old versions
Topic: Is hardware available for AtomixMp3 ?
PFD50PRO InfinityMember since 2007
I would like a cheap setup like DJ Control MP3
geposted Sat 12 May 07 @ 7:03 pm
sbangsPRO InfinityMember since 2004
for controler support you must migrate to virtual dj
you can do so at a discount as you own atomix
geposted Sat 12 May 07 @ 7:52 pm
Can you do this with the Home Edition?
geposted Sat 12 May 07 @ 8:59 pm
yes basic support is provided for the console.
for full features and acess to a mapper you must get pro
comparison
geposted Sat 12 May 07 @ 10:37 pm
Thanks for the help so far.
I only bought AtomixMp3 the other night and now realise I should just have went straight for the hardware as this comes with software I could have used. What a dunderhead I am. I have seen the upgreade page but can't find this now.
geposted Sat 12 May 07 @ 10:57 pm
upgrade here
dont be downheartened atomix mp3 is aslo a great juke box :) for personal use
geposted Sun 13 May 07 @ 12:58 am
That link is dead
geposted Sun 13 May 07 @ 12:45 pm
geposted Sun 13 May 07 @ 2:11 pm
i downloaded several skins and effects to my atomix mp3 software the full version 2.3 but i can't have them on my software to use i still only have the the default interface, what do i need to have the skin changed and to have more sound effects?
geposted Mon 14 May 07 @ 4:18 pm
place the skins in
C:/programfiles/atomixmp3/skins
and effects in /atomixmp3/effects
effects then can be loaded from the fx pane
and skins changed on general options
geposted Mon 14 May 07 @ 10:04 pm
