Forum: Old versions
Topic: Issues with Soundcard
I have been using Virtual DJ for a while now. I never really had any issues. I haven't used it in a year. I am trying to use the headphone plugin now and it is not working.
Sound card: Creative Audigy 2 ZS
In VDJ:
I selected the third option (4.1, headphones and speakers plugged into 2 different ports).
checked output 7.1
In Creative Audio Console:
Speakers/Headphone Selection: 7.1 Speakers
Basically, I don't even have any of the headphone plugins enabled and i can ONLY hear it from my headphones, not from my speakers. Master and headphone volume are all the way up on VDJ and on my PC.
Any thoughts? This is starting to bug me!
Thanks.
geposted Sat 12 May 07 @ 9:12 pm
What version r u using? 3x or 4x... FYI i also using audigy 2zs (one of my 3 asio soundcard) n did not encounter problem of urs.. Do u using external mixer or any other controller? tell more about ur problem.
I am actually using 3x, the reason is I had 4x and couldn't get the headphone plugin to work, and really wasn't ready to move to the new version. I am not using any external mixers at all.
ok try this.. dun koe if its werks.. i never use without mixer.,(only during mixstation 2..long time ) so try this..
use ur version 4 select
input: none
output: headphones
soundcard:4:1.. or creative audigy asio
hope that helps.:)
in creative console... it doesnt matter ...
