Forum: Old versions
Topic: Numark Total Control - already out?
i checked pssl.com just now and the Total Control is already in stock? Has anyone actually bought the unit? Any reviews?
Also - i know this controller doesnt have any soundcard on it. i have the old herc mk1 - was just wondering if i could use that to act as my soundcard and then use the Total Control as my controller?
geposted Sun 13 May 07 @ 3:15 pm
Mine has been ordered, when it comes in I will post a review. As to your second question I do not see why the Herc cuold not be used as a sound card. So please register your Virtual DJ software and lets start having fun!
Elsewhere on this forum, someone (a beta tester?) suggested the Total Control jog wheels are permanently set to "scratch" with no option to disable or reassign. For us mostly wedding types, there's a huge risk of bumping the wheel and cutting it up by mistake.
Can someone clarify this, please?
On the promotional pictures on Numarks website there is a "scratch" button below the browser dial
One would assume that this button alternates between scratch mode and jog mode.
I hope this is the case.
If not I'm going to stay clear of it as well.
I noticed that the DMC2 has the same button.
Can the VIP member from Numark that reads these forums clarify this for us please?
I'll have mine on tuesday
It better not just scratch or mines going back
I am sure it can be changed like MK2 has it too.
just ordered mine should be here in few
anyone know how to update tp cue pro
i heard u can once u order the totalcontrol cue and cue le
I could be wrong, with Cue I do not think it is a question of upgrading. I think you would need to buy the softeware from Numark, and when VDJ is upgraded y as a Cue user you will be able to also. I am not a Numark rep. (much to my chagrin) so this might not be right. But I have had Cue since Dec. 06 and I have not heard of "Upgrading" to the full version. I hope this helps.
Ok, so it has issues with Traktor. I've SEEN and USED this unit on Numark Cue - it DOES work, but I didn't spend long checking it out and I'm not very familiar with VDJ at the moment. So there's a few bugs - they can be ironed out.
i have had mine for about a week and use it with virtual vinyl. it has worked flawless. at first i couldnt get the headphones to work but figured it out. it comes with cue le and trackor. if you want to upgrade its 89.99 thru pssl.com
Hello everyone
Where can you order Numark Total control ???
I found it already
But can you pre -listen with it ???
got mmine todayand hooked it up
its notthat bad.couple of things im stuck with or have ? about.
first i need an external usb interface use my headphones to cue up the next song cornrect? i was thinking of wating for the numarki/o comes out or i been reqding that man people use the maya44.
now this willlet me cuew my songsand output to an amp and such..
the second thing
when u movethe jog wheel while mixin itmake a bit of noise .anyone know why it does this?
thanks for all your help
