Forum: Old versions
Topic: Numark CM200-USB DJ mixer
has any one used this mixer with vdj with any sucsess. hows the sound quality and the latency. i dont use tccd or tcv's. numark doesn't give the sound card specs or anything of that sort.
does the vdj remember what card (channel) to go through when setup corectly. if it works well this would settle a few of my issues as i do still run a old tape deck as well lol and i do need a new mixer as mine is about 10 years old and used and abused.
thanks for the info and keep up the great help and support as these forams a great infuance to my soon buying vdj as soon as the tax return comes back.
thanks again
geposted Mon 14 May 07 @ 4:27 am
and how does it work with the dac3 or numark dmc2. which is better
it is a dual usb soundcard
basicaly each channel is a seprate card
in vdj you need to set it to
ins : none
outs: external mixer
Card: two cards
1. cm20001
2. cm 20002
the DM2 is a much newer and more featured controler
i would recommend that
remember to use these nice toys ul need virtual dj pro:)
hope that helps
Also it is not midi device, just a mixer/soundcard.
