Forum: Old versions
Topic: Mk 2 no longer responding to loop controls
Hi,
Mk2 no longer responds to the usual loop triggers of 1 beat on 1 button, 2 beat loop on button 2 etc.
Looping now has to be done via software for 4.3 is this true?
geposted Mon 14 May 07 @ 4:34 pm
NO. u could still assign using ur MK2 when using with 4.3.. It still the same but only differ a bit.. example.. u set too loop then press 2 (it depend whether u put 4 beat) and then button 1 is mutiply it by 2( now became 8 beat), button 3 divide it by 2 (now became 2 beat) and so on.. and it also apply to the effect section.. where button 2 is the effect u load then button 1 going forward the next effect and button 3 backwards.etc.
Arrgh, so it is supposed to be like that! I figured that that was what it was doing, just thought it to be a bit odd as it defeats the object of the "preset" buttons - for looping anyway.
Thanks very much spinna.
Peace
ur welcome:)
