Forum: Old versions
Topic: Stuck in mid-air with the whole setup
ECUAMORPRO InfinityMember since 2004
I hate to sound like the usual newbie but I am having problems with setting up. I just recently purchased a Numark 950USB that I was planning to use for controlling the functions from Virtual DJ. So I hooked it up to the back of my Soundblaster Audigy 2 using a Y-adapter (1/8" Right-Angle to Two RCA Plugs), which is plugged on the master output. Both USB cables that came with the mixer was plugged properly from the computer to the mixer. Then I purchased my copy of VDJ Full Edition and configured the sound as: Input:None, Output:External Mixer, Sound Cards: 2 soundcards, showing USB Audio Codec on both 1st & 2nd cards. The problem that I keep getting is that the music blasts on my headphones, instead of both my headphones and speakers. I tried changing the sound configuration to see if I could stumble on fixing it but no luck. On top of that, the only control that I have for VDJ on my 950USB is the Cue Trim lever from CH1 to CH2, along with the Bass, Treble and Trim. I thought the I would get the full control like the crossfader, meaning all VDJ levers move simultaneously as I move on the 950USB. Can someone help me out?
My speaker system is a Logitech 2.1 speaker system.
geposted Tue 15 May 07 @ 6:18 am
