Forum: Old versions
Topic: Direct X Drivers error
2 Days ago I was trying to use VDj with the MK2 and it freezes. The air message says I have problem with the direct x drivers.
I have download them already but , I just want to make sure how to re installing with out making a mess.
Do I have to unisntalled the old drivers??? How do I do that ? I don't seem to find them on my list
(Add or remove programs screen)).
Please advise
Vic
geposted Tue 15 May 07 @ 9:19 pm
strangly enough this isnt related to direct x it means that the sound config isnt quite correct
check that you have the correct settings , if not change and apply close the software and run it again all should be well again :)
Thank you guys
