I admit it. I've been using the headphone jack to send audio to my mixer but it's time to buy a USB soundcard. Which one do you recommend?
I just ordered a Total Control, use a USB hard drive to store my music and the VDJ program is on the laptop's hard drive (if all that matters).
geposted Tue 15 May 07 @ 11:35 pm
If you not plan to use Timecode then take Sound Blaster Live 5.1 USB, otherwise get Maya 44 USB or ESI U46DJ.
I saw negative comments about Total Control :/
geposted Tue 15 May 07 @ 11:47 pm
Gigaport has only outputs, and you need inputs for timecode, so do as Alf says . . . or else lol
geposted Wed 16 May 07 @ 12:15 am
Maya44 (4ins x 4outs) just been re-released only $99 at www.PSSL.com
geposted Wed 16 May 07 @ 4:55 am
if you are not using time codes the djio is a pretty nice card when paired with the total control.
geposted Wed 16 May 07 @ 5:31 am
i just got the audio gene was wondering what is the right connection to my mixer and table top turntables
geposted Sat 19 May 07 @ 12:27 am
