It seems like Virtual DJ supports the AAC file format but I didn't find anything definitive on this. Can someone confirm which file formats are supported in Virtual DJ? Is there somewhere I should be looking. I didn't seem to find that information in the user manual I downloaded.
geposted Wed 16 May 07 @ 4:12 am
hi broodwich
can't help you directly on this one but sometimes when i'm stuck on a subject i put a search in the tool box at the top of the page more often than not after a little reading of the posts you usually find what your looking for if not just hang loose and wait for sky and norway, or one or two of the others to get round to you they know there stuff so you will be in capable hands...best of luck...
Tayla
Tayla
geposted Wed 16 May 07 @ 1:38 pm
i belive so you may need to add it as a extention on the codecs tab
geposted Wed 16 May 07 @ 1:44 pm
Well I downloaded the demo and although I haven't loaded any AAC files into Virtual DJ, I did see that it is supported by default. BTW, the extension for AAC files is .m4a.
geposted Thu 17 May 07 @ 7:59 pm
Does anyone know if there are any problems playing VBR MP3s with VDJ? I know this can be a problem in some other software applications.
geposted Fri 18 May 07 @ 7:51 pm
nope..no problems at all..
even oggs
cheers
even oggs
cheers
geposted Fri 18 May 07 @ 8:25 pm
