Forum: Old versions
Topic: Build 13
I see a new version (13) is available for Mac - anyone know whats been changed?
geposted Thu 17 May 07 @ 3:31 am
i think the auto update check is new...
You can use an * to search!!
Yahoo!! Love you guys
Does anyone know if it fixes the problem of VDJ just crashing for no reason when playing?
Could the dev or staff post what was changed in the latest build?
I know this used to happen with the PC builds..
Thanks
this was a small bug fix not a full release so it wont be on the site
R13:
Fixed : Search
R13:
Fixed : Search
Thanks!
