Forum: Old versions
Topic: Virtual DJ 4.3 version_mixing
Hello all,
Is it possible to execute two separate Virtual DJ sessions to mix up to four songs? I've learned to mix 2 songs and keep them in synch & mixed. I would like to mix in a 3rd and 4th song. I am using the motherboards onboard sound card (realtek) and Creative X-FI soundcard.
Thanks.
geposted Thu 17 May 07 @ 5:34 am
Yes, inable multi instance in Settings of VDJ and than you can have 4 decks or more as only your machine specs is the limit.
Hello DJ-Alf. I've been unable to find the setting which you indicated on your previous email.
You can also try the multi instance skin available in the downliad area.
