Hello all,
Is it possible to execute two separate Virtual DJ sessions to mix up to four songs? I've learned to mix 2 songs and keep them in synch & mixed. I would like to mix in a 3rd and 4th song. I am using the motherboards onboard sound card (realtek) and Creative X-FI soundcard.
Thanks.
Thanks.
geposted Thu 17 May 07 @ 5:34 am
Yes, inable multi instance in Settings of VDJ and than you can have 4 decks or more as only your machine specs is the limit.
geposted Thu 17 May 07 @ 1:12 pm
Hello DJ-Alf. I've been unable to find the setting which you indicated on your previous email.
geposted Mon 28 May 07 @ 5:07 pm
You can also try the multi instance skin available in the downliad area.
geposted Mon 28 May 07 @ 5:24 pm
