Forum: Old versions
Topic: buyin dj console mk2
hi i wanna buy a dj console mk2 i live in aus and the distributer here charges over 600$ it redicuesly over priced..... any ideas on were i can get it from for a reasonable price....
thnx every1
geposted Thu 17 May 07 @ 2:36 pm
well i buy the mk2 for $899 singapore dollars early 2006.. woah that much but yeah it true. And to ur question, try search the internet. I find it quite cheaper than what they are offering u rite now:)
I just bought the MK2 and to be honest and in my opinion you would be better buying a decent sound card and the VDJ Pro version unless you have a sh*t kicking spec of a PC.
if you buy from www.amazon.co.uk then it will cost you 312 AUS dollars.
Add shipping to that and it will be cheaper than you can get it for. Its quite a light product so shipping would not be that expensive
would people be sugesting the maya44 usb sound card then?
Yes, Maya 44 is a good sound card but than you will not have a controller so you can take something like Numark Total Control.
i was told wif tccd that i would hav full control of vdj....as in i would even see the pitch slider move up and down on the software as i move it on my cdj
