Forum: Old versions
Topic: Whats the problem?
I posted this in the forums and didn't really get any solution, so i guess its a bug?
VDJ runs perfectly for me in every sense, untill i plug in a usb mouse, then anything after 20 minutes to an hour the skin will freeze, lock up and i can't do anything till i close down the software.
Video & music continue to play ok, but once the song/video thats playing stops, there is no way to get another one playing.
I had this problem in 4.2 trial version and now in 4.3 Pro version and on 3 different brand of laptops.
Current specs are:
ntel® Centrino® Duo Mobile Technology
• Intel® Core™ 2 Duo processor T5600
• 1.83 GHz , Level 2 cache 2 MB
• Intel® PRO/Wireless 3945 802.11a/b/g Integrated Wireless LAN
Operating system installed
Genuine Windows Vista™ Home Premium
Standard memory
2048 MB
Maximum memory
Supports up to 2 GB DDR2 memory
Memory layout
(2 x 1024 MB)
Internal drives
Internal hard disk drive
320 GB (2 x 160 GB)
Hard disk controller
SATA Hard Disk Drive
Hard disk drive speed
5400 rpm
Optical drive type
Lightscribe Super Multi DVD Writer (+/-R +/-RW) with Double Layer support
System features
Memory card device
5-in-1 integrated Digital Media Reader for Secure Digital cards, MultiMedia cards, Memory Stick, Memory Stick Pro, or xD Picture cards
Modem
High speed 56K modem
Network interface
Ethernet 10/100BT integrated network interface
Wireless technologies
Wireless capability
Bluetooth® wireless networking
External I/O ports
1 VGA port; 1 HDMI port; 4 USB 2.0 ports; 1 IEEE-1394; 1 RJ 11 modem connector; 1 RJ 45 Ethernet connector; S-video TV out; Remote control infrared port (Remote Control optional); 2 Headphones-out one w/ SPDIF Digital Audio, 1 Microphone-in port; Cable docking connector
Video capture interface
IEEE 1394 FireWire® Interface
Expansion slots
One ExpressCard/54 slot (also supports ExpressCard/34)
Display size
17" WXGA+ High Definition BrightView Widescreen
Display resolution
1440 x 900
Video adapter
NVIDIA® GeForce™ Go 7600
Video RAM
with 512 MB dedicated video memory
TV tuner
TV Tuner DVB-T, (DVB-T service not available in Ireland)
Control panel
HP QuickPlay media player software and its dedicated menu controls, music and DVD buttons
Webcam
HP Pavilion webcam with stereo integrated microphones
Remote control
with remote control
Internal audio
3D Sound Blaster Pro compatible sound 16 bit integrated
Speakers and microphone
Altec Lansing® speakers
Keyboard
Full size desktop keyboard (with separate numeric keypad layout)
Pointing device
Touch Pad with On/Off button and dedicated vertical Scroll Up/Down pad, volume control, mute buttons, 2 Quick Launch Buttons
Power supply type
90 W AC Power Adapter
Software - Productivity & finance
Microsoft® Works 8.5
Pre-installed software
Microsoft® Internet Explorer 7.0; Windows Mail; Adobe® Reader 7.0
Optical drive driver software
Windows Media Player ; HP Photosmart Essential, Windows Photo Gallery ; DVD Play ; Windows Movie Maker, Windows DVD Maker, Roxio MyDVD Basic ; Roxio Creator Basic ; Windows Media center, QuickPlay Direct and QuickPlay for Windows ; TV Play
Software included
Recovery partition (including possibility to recover system, applications and drivers separately); Optional re-allocation of recovery partition; Recovery CD/DVD creation tool; Symantec™ Norton Internet Security™ 2007 (60 days live update); Notebook Help & Support
geposted Thu 17 May 07 @ 3:59 pm
perhaps the usb ports are on conflicting irqs with somthing
Maybe thats the case. That just starts to go beyond what i understand and feel comfortable investigating. I've seen the odd post on this, but my grey matter won't comprehend it.
It looks a little too complicated, plus i haven't seen any posts about fixing this in vista, only XP
Gary
Did you use the same mouse in the '3 different brand laptops'? I'd start by removing the mouse drivers if any and using the inbox ones or if you only have the default inbox drivers then installing new ones.
I'd also try to turn off the advanced power settings (control panel/power options) such as pci express link state mgmt, usb selective suspend and updating display adapter and chipset drivers, presumably intel/nvidia in case of the listed configuration. After that I'd look for BIOS updates...
If all else fails use task managers (ctrl+shift+esc) right click virtualdj process and "Create dump file" and send it to service@virtualdj.com or support@ ... I don't remember where the dump file ends up and which is the correct email though :-)
make a support ticket when sending in dump files please
support ticket
