Forum: Old versions
Topic: Cueing Music ??
Allo... Please, after setting cues on my music, is it possible (while DECK1 is playing) to have the have DECK2 start playing simultaneouly at the "last" cue on DECK1? If so, please how?
Also, what is(are) difference between SYNC and BEATLOCK?
Thanks peps :)
geposted Fri 18 May 07 @ 3:50 pm
yo! DJs.... please, help out a newcomer.... the answer is probably simple.... but i've being trying to figure this out on my own but no success.
thanks to anyone and everyone in advance.
sync automaticaly matches the beats at a one of point
beat lock keeps them locked at the same tempo bpm and gain untill it is dissabled
Is there any way for them to be locked at gain, but NOT tempo? I find the tempo is off 70% of the time, and I trust my instincts better. But I would LOVE to not have to mess with the gain on each mix!
Thanks Skyfxl 4 your answer.... what about the cueing of music .... how can i get it to start playing simulteanously as the cue on other music is reached? Anyone please.
you mean auto play? did you click the wand?
it will do it automagicaly if you press the wand symbol
thanks guys ... i'll try playing around with the automix.... although, i would prefer to have control with the mixing myself. Once again, i do apprieciate both of you lookout.
