Forum: Old versions
Topic: Cueing Music ??
ifesPRO InfinityMember since 2006
Allo... Please, after setting cues on my music, is it possible (while DECK1 is playing) to have the have DECK2 start playing simultaneouly at the "last" cue on DECK1? If so, please how?
Also, what is(are) difference between SYNC and BEATLOCK?
Thanks peps :)
geposted Fri 18 May 07 @ 3:50 pm
yo! DJs.... please, help out a newcomer.... the answer is probably simple.... but i've being trying to figure this out on my own but no success.
thanks to anyone and everyone in advance.
geposted Sat 19 May 07 @ 8:17 am
sbangsPRO InfinityMember since 2004
sync automaticaly matches the beats at a one of point
beat lock keeps them locked at the same tempo bpm and gain untill it is dissabled
geposted Sat 19 May 07 @ 10:30 am
Is there any way for them to be locked at gain, but NOT tempo? I find the tempo is off 70% of the time, and I trust my instincts better. But I would LOVE to not have to mess with the gain on each mix!
geposted Tue 22 May 07 @ 2:54 am
Thanks Skyfxl 4 your answer.... what about the cueing of music .... how can i get it to start playing simulteanously as the cue on other music is reached? Anyone please.
geposted Wed 23 May 07 @ 5:39 am
jchiarPRO InfinityMember since 2005
you mean auto play? did you click the wand?
geposted Wed 23 May 07 @ 5:48 pm
it will do it automagicaly if you press the wand symbol
geposted Wed 23 May 07 @ 10:29 pm
thanks guys ... i'll try playing around with the automix.... although, i would prefer to have control with the mixing myself. Once again, i do apprieciate both of you lookout.
geposted Thu 24 May 07 @ 5:56 am
