Forum: Old versions
Topic: Rip Vinyl --> impossible to save
Hi,
i got a reloop rp-200MK3 connected to my MK2.
I want to rip vinyl - i set up in ripvinyl.exe that came with virtualdj the input 3 / 4 ASIO to record.
It works fine - i can hear the track playing from vinyl - then i press record and when i want to save the mp3 it says Impossible to save C:\...... .mp3
I got lame and stuff installed and set up correct...
please help - need to paly tonite and before that i want to rip those vinyls...
geposted Sat 19 May 07 @ 2:05 pm
Fraid I don't know what's wrong with the Rip Vinyl software, but if nobody else has a suggestion you could download a free sound program called "audacity" (from www.download.com )
Works very well for recording. (and lets you make other adjustments/add effects)
geposted Sat 19 May 07 @ 2:46 pm
after cleaning Registry and a clean re-install all works fine now...
cheers
geposted Sat 19 May 07 @ 11:01 pm
DJ ELPRO InfinityMember since 2005
I'm having the same issue. What kind of registry cleaning did you do?
geposted Wed 30 May 07 @ 7:08 am
You can use : VirtualDJ Registry Key Removal or Registry Tool v1.5.
it removes everything when you removing vdj.
You can find them here!
geposted Wed 30 May 07 @ 10:10 pm
