Forum: Old versions
Topic: Strange iTunes import/browsing problem
I don't know if this is a bug or not so I thought I'd post it here first.
When I import my playlist from iTunes it seems to work fine, displaying the correct number of tracks etc.
But, after finishing analyzing every track a lot of the files show the "yellow ?" on the record.
It has not been analyzed and when trying to load it to a deck it says -error.
At first I thought it was just a corrupted file, but after having a second look it was way to many files for this to be the case.
Alse, when browsing the file directly(and not from the virtual folder) it would both load to deck and analyze just fine.
The strange part is that after the analyzing was done browsing directly, the track would then show up correct in the Virtual Folder containing my iTunes music....
Does this mean that the software is getting some of the file locations/shortcuts wrong on the first import and corrects this when analyzing directly?
Or is it simply something wrong??
The reason I ask is that the same imported iTunes playlist works directly in several other softwares. So why not with my Virtual Vinyl?
Whatever is causing the problem, do anybody know how to solve this in the best possible way??
(You might understand that browsing for thousand of tracks directly and analyzing one by one is not a very good option..just an extremely time consuming and frustrating job)
geposted Mon 21 May 07 @ 2:46 am
same exact problem here...waiting for a fix.........
