1. Is't working mk1 and virtualdj 3.4 in window vista ?
2.witch is the best laptop for virtualdj (audio only) & presentation :
lenovo y400 (945443a),core 2 duo t5500,GeForce go7300 or
toshiba satellite a100-2212e,core 2 duo t5200,ATI radeon x1400.
i know the lenovo have a better spec but it is good brand ?
before i used toshiba satellite p25,pentium 4 2.8 ht,GeForce 5200,17' but is heavy to carry around.
thanks for any help....= )
geposted Mon 21 May 07 @ 3:41 am
1st you need to update to VDJ 4.3 and DL the Vista drivers for the MK1/MK2.
2nd I personally love my Toshibas, I've had 6 of them and always had good luck.
The one thing about them now is that a lot of them use those GeForce "go" video cards and they do not work well with VDJ video unless you use Vista and DL all the newest drivers from Toshiba.com
I've never used a lenovo laptop but it has an ATI card that should work fine with VDJ Video. What I would do is check out the warranty and see if they have a service center close to you that you can just walk in to and drop it of Most laptop service centers have a 2 day turn around, it's the shipping that adds to the long wait for the return of your computer.
Also check the return police of the store and see how long and if there is a fee for returning the computer if you don't like it.
If you are just using it for music you should not have a problem with either I would choose the one with the biggest 7200rpm HDD.
geposted Mon 21 May 07 @ 4:06 am
thanx for help...: )
geposted Mon 21 May 07 @ 4:42 am
