Forum: Old versions
Topic: 7.1 HD Sound
PFD50PRO InfinityMember since 2007
I have a new PC with an Intel 7.1 HD sound chipset onboard. Should I use this rather than the Hercules as my sound card.
What would I need to do to set it up correctly. i.e do I need to link back to input on PC from the Herc etc...
geposted Tue 22 May 07 @ 3:31 pm
DJ-ALFPRO InfinityModeratorMember since 2005
It is better to use Hercules sound card IMO.
geposted Tue 22 May 07 @ 5:40 pm
Why is that, ALF?
Just curious !
geposted Tue 22 May 07 @ 6:19 pm
I have yet to see an onboard sound card that had "professional" sound quality. I am sure in the future that may change but not currently
Rusty
geposted Tue 22 May 07 @ 7:02 pm
spinnaJPRO InfinityMember since 2004
use the mk2 as ur sound card. its betta :)
geposted Tue 22 May 07 @ 8:30 pm
bryantpb wrote :
Why is that, ALF?
Just curious !
Better dynamics of sound :)
on board sound has electronic interference, that's why USB cards are better and everyone use them ;)
geposted Wed 23 May 07 @ 5:54 pm
Sound Intel® High Definition Audio 7.1
3 front audio ports, 6 rear analog audio ports & 2
rear digital audio ports
Thats what the PC has and a mutidude of config settings
full spec at http://h20195.www2.hp.com/V2/pdf/c00992291.pdf
It just that I get a real shitty hiss when my VDJ software gain is anything more than 0
geposted Thu 24 May 07 @ 12:45 am
You can't gain over 0dB with any sound card because you will have shape of sound and distortion, for that you should use external mixer.
geposted Thu 24 May 07 @ 8:26 pm
