Forum: Old versions
Topic: MAYA44 USB
hi..is this supported?the card has core audio driver and it works perfectly on mac. will it support timecoed with this soundcard?thanx
geposted Wed 23 May 07 @ 11:07 am
currently virtual vinyl is the only card that can use tcv on mac
future updates should add more cards.
Where can we buy this card ?
Cheers
where do you live are you looking for maya or virtual vinyl?
Hello !
I'm living in South of France. I've got actually a Maya card using VDJ on a PC.
I have just bought a Mac. It will be at home soon and if it works fine with Virtual Vnyl, I think I will also invest in this type of card.
Cheers
Oops, it's a little bit too expensive for my budget.
Apparently they only sell the product as a bundle. We can't buy for example only the sound card.
currently no perhaps in the future
It lets me some time to make some (others) saves...
I have also a BCD 2000. Perhaps I will try with it.
