hi all
i have time code disks running with my mixer into a esi maya 44 pci sound card,
the machine is running xp.. it has 1gig of ram and a 2gig amd cpu,
the version of virtual dj is 4.0.
everything is running fine until i try speed up my deck with the pitch control,
it skips and pauses... the more i speed up the worse it gets...
i have gone into the forums and looked for this problem but i cant see it...
does any one have any ideas,
any help would be great
(also i have ran dpc latency checker (v1.0.0) and everything was very good (absolute max 357))
again thanks
dj jarvis (rep of ireland)
again thanks
geposted Thu 24 May 07 @ 5:49 pm
hi again... so no replys to my last post... this is not good ... someone out in virtual dj land
must have come across this problem before.... again i have gone into the forums for an answer but cant find anything... it not if im not bothering my arse to look... even if its what looks to be a stupid question to the pros on this site a little help to a noob would not hurt
gettting a little pissed of with the system... lack of support ... 3 months waiting for disks (but my credit card was charged 2 days later.... funny that!!)
so restore my faith in virtual dj system and the people who use it
HELP ME SOLVE THIS PROBLEM
thankyouallverymuchforyourhelpandtimeinadvance
dj jarvis
dj jarvis
geposted Mon 04 Jun 07 @ 7:18 pm
Whose TCV's are you using? What cartridges are you using? I don't use TCV, but maybe someone that does, will answer you. All this time, and you have not registered, why not?
geposted Mon 04 Jun 07 @ 7:37 pm
Register yourself as a Pro user first to get more support.
Lower your performance in the performance tab. Enter "Auto" in the latency tab.
geposted Mon 04 Jun 07 @ 8:06 pm
