Forum: Old versions
Topic: Converting Pc to Mac record cases
I am about to switch to VDJ on the mac but i have a question.
I currently use PCDJfx and have all my record cases on it (pc)
I can convert those to a m3u list but neither my mac (including itunes) will read that due to the way it formats the drive letters etc.
What is the best way to do this conversion?
August
geposted Thu 24 May 07 @ 6:52 pm
you should be able to import those playlists
Well heres the story,
I have PCDJ record case that I exported to a m3u that works fine on my PC and plays in Itunes on PC just fine.
But when I open the m3u on my Mac it doesn't understand the playlist so i doubt it will work if I get the Virtualdj for mac. So I am hesitating to purchase because I have many hours invested in my record cases and want to convert them to the Mac and make sure everything works before the switch.
Tia
virtual dj builds its own record case aslo in a few minutes automaticaly if you right click on local database and press scan hdd aslo
Tia
VDJ AUTOMATICALLY imports your Itunes playlists.
Works just fine.
Just be aware that once they are imported they do not change if they change in itunes again.
Hey Guys,
Sorry Maybe I am not making my self clear.
I have the play lists on the Pc.
They wont import on my Mac at all due to the way mac handles drives.
Its not for eg I:\mp3\a\avril\avril - sk8rboy.mp3
its /Volumes/Mp3/a/avril/avril - sk8rboy.mp3
I need to convert PC playlists to Mac.
