Forum: Old versions
Topic: Input/headphone question
Hey guy's I've just bought a MK2 dj console and I've got a couple of questions here goes:
Firstly is it possible to have both deck A and Deck B playing through the headphones independent of the main mix?
Secondly
At the moment when I'm connecting anything through the inputs on the console I'm getting loads of interference and the sound is very distorted any ideas why this might be or could the console be faulty?
geposted Thu 24 May 07 @ 7:36 pm
what version do you use?
Virtual DJ 3.4.1
Scrap the second question sorted that now newbie mistake lol but still not sure about the headphones.
You have a switch for that, Deck A/B, Mix or Split, did you use it? Just next to the Headphone input.
Yea i used that but i wanted a&b at the same time without just listening to what's going through channel 1&2
Not sure what you mean, but if you want to hear them both than put prelistening nob on "Mix", or you can connect your headphones on left channel (1&2) and in Settings put it on Simple output so you can hear both decks on one stereo output.
Basically is it possible to cue the master on the headphones so i can hear the master and deck a or deck b?
Yes, like I explained above.
What kind of Sound card does one need in order to hear two songs play on Headphones whilst only one song is playing on the main speakers, OR, how should I set it to play two songs from both decks on the headphones
a 5.1 or greater soundcard
with two stero outs
