Forum: Old versions
Topic: Input/headphone question
Hey guy's I've just bought a MK2 dj console and I've got a couple of questions here goes:
Firstly is it possible to have both deck A and Deck B playing through the headphones independent of the main mix?
Secondly
At the moment when I'm connecting anything through the inputs on the console I'm getting loads of interference and the sound is very distorted any ideas why this might be or could the console be faulty?
geposted Thu 24 May 07 @ 7:36 pm
sbangsPRO InfinityMember since 2004
what version do you use?
geposted Thu 24 May 07 @ 7:49 pm
Virtual DJ 3.4.1
geposted Thu 24 May 07 @ 7:52 pm
Scrap the second question sorted that now newbie mistake lol but still not sure about the headphones.
geposted Thu 24 May 07 @ 8:10 pm
DJ-ALFPRO InfinityModeratorMember since 2005
You have a switch for that, Deck A/B, Mix or Split, did you use it? Just next to the Headphone input.
geposted Thu 24 May 07 @ 8:28 pm
Yea i used that but i wanted a&b at the same time without just listening to what's going through channel 1&2
geposted Thu 24 May 07 @ 8:30 pm
Not sure what you mean, but if you want to hear them both than put prelistening nob on "Mix", or you can connect your headphones on left channel (1&2) and in Settings put it on Simple output so you can hear both decks on one stereo output.
geposted Fri 25 May 07 @ 10:44 am
Basically is it possible to cue the master on the headphones so i can hear the master and deck a or deck b?
geposted Fri 25 May 07 @ 5:20 pm
Yes, like I explained above.
geposted Sat 26 May 07 @ 4:53 am
smaelieHome userMember since 2007
What kind of Sound card does one need in order to hear two songs play on Headphones whilst only one song is playing on the main speakers, OR, how should I set it to play two songs from both decks on the headphones
geposted Thu 31 May 07 @ 11:24 am
a 5.1 or greater soundcard
with two stero outs
geposted Thu 31 May 07 @ 2:03 pm
