Forum: Old versions
Topic: Questions about Virtual DJ Timecoded CD use
I currently use The Hercules DJ Console MK2 with virtual DJ version 3. I have recently purchased a set of Denon DN-S3500 CD turntables. I set everything up correctly to use the Timecode feature (only 5 minute trial use) it worked initally but after a few seconds the song would skip and there would be an ocassional popping sound. This happened on both CD players mainly when I tried to scratch. I was planning on upgrading to Virtual DJ Pro mainly for the timecode CD feature but am now unsure due to this problem. Is this common? Can anybody help?
Thanks
geposted Thu 24 May 07 @ 10:10 pm
hi there sounds like the time code signal is to loud try lowering the db by 13
using a free editor such as audacity
then burn a new cd
