Forum: Old versions
Topic: need help with sound card problem....
i am using an m-audio external sound card with my dell laptop. the program has been working fine for 1 month and 2 days ago it decided to start to mess with me. when i start the vdj program and i load a song it won't play. i have to then go into the config and swith it to my internal sound card then play the track for a second then go back into config and then i can choose my m-audio card and it will play fine.
i just reformatted my laptop and i am still having the same problem. i have all the updated drivers for my laptop and sound card.
can anyone please help me figure this out before i smash my $1800.00 laptop.
Thanks Mark
geposted Fri 25 May 07 @ 12:47 am
DJ-ALFPRO InfinityModeratorMember since 2005
Do you connect something else on USB ports besides sound card? Try only sound card plugged in and see is it better.
Write down your machine Specs and what OS do U use.
geposted Fri 25 May 07 @ 10:40 am
