make your own...with many more inputs
only 35 bucks
http://www.ultimarc.com/ipacve.html
only 35 bucks
geposted Sat 26 May 07 @ 12:57 am
Very similar to the one I used in my setup. This one uses the keyboard port instead, they say it is better, who knows. So many possibilities.
Also only 35 bucks.
http://groovygamegear.com/webstore/index.php?main_page=product_info&products_id=199&zenid=1f8b228488cbc07758b090146ae9ec93
Also only 35 bucks.
geposted Sat 26 May 07 @ 5:33 pm
whats your controller look like?
geposted Sat 26 May 07 @ 11:41 pm
It was a ton of work, but a real blast to play with.
geposted Sun 27 May 07 @ 12:15 am
Man does that look sweet Mills.......
geposted Sun 27 May 07 @ 12:41 am
thats pimp...i thinki would of put the players on the bottom....but nice job.
question though.
when u hook up the switches.....does 1 sde go to ground then the other pin goes to [up down etc]
question though.
geposted Sun 27 May 07 @ 3:54 am
Believe me I looked at every possible arrangement once I had the panels cut. I felt the top position fit my style best. As far as the button hookup, it was actually fairly easy. Each arcade button microswitch has common (ground), a normally open, and a normally close position. The common of all switches is daisy chained and wired into the ground on the keywhiz, and then each normally open is connected to on of the inputs. I also used 6 of the 'shazaam' inputs, which run both the normal ground and the 'shazaam' ground at the same time to activate an extra set of inputs. I really wanted to get a track ball in there, but they are just too big behind the panel.
The powered USB hub is now permanently in the box, hard drives are next : )
If anyone has ideas left for the buttons, I still have 4 on each side open.
geposted Sun 27 May 07 @ 7:03 am
Nice clean wiring job too Mills, you are a true craftsman.
geposted Sun 27 May 07 @ 4:30 pm
WWWWWWWWWOOOOOOOOOOOOOOWWWWWWWWWWWW
geposted Sun 27 May 07 @ 6:55 pm
Thanks guys. TearEmUp I do envy your diamond plating, that looks sweet!
And TexZK - your flanger gets two buttons : )
geposted Sun 27 May 07 @ 11:28 pm
