Here:
http://www.shopmagenta.com/product/MAU1003573.aspx?refer=99914
Product Description - HP Compaq Mobile Workstation nw9440 - Core 2 Duo T7600 2.33 GHz - 17" TFT
Dimensions (WxDxH) - 39.3 cm x 27.5 cm x 3.3 cm
Weight - 3.4 kg
Localisation - English / United Kingdom
Platform Technology - Intel Centrino Duo
Windows Vista Certification - Windows Vista Premium Ready
System Type - Notebook
Built-in Devices - Stereo speakers, wireless LAN aerial, Bluetooth aerial
Embedded Security - Trusted Platform Module (TPM 1.2) Security Chip , SmartCard reader
Processor - Intel Core 2 Duo T7600 / 2.33 GHz ( Dual-Core )
Cache Memory - 4 MB - L2 Cache
RAM - 2 GB (installed) / 4 GB (max) - DDR II SDRAM - 667 MHz
Card Reader - 7 in 1
Hard Drive - 100 GB - Serial ATA-150 - 7200 rpm
Optical Storage - DVD±RW (+R double layer) / DVD-RAM - integrated with LightScribe Technology
Display - 17" TFT active matrix 1920 x 1200 ( WUXGA )
Graphics Controller - NVIDIA Quadro FX 1500M - 512 MB
Audio Output - Sound card
Telecom - Fax / modem - MDC - 56 Kbps
Networking - Network adapter - Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Bluetooth 2.0 EDR
Wireless NIC - Intel PRO/Wireless 3945ABG
Input Device - Keyboard, touchpad, pointing stick
Power - AC 120/230 V ( 50/60 Hz )
Battery - Lithium Ion
Run Time (Up To) - 3 hour(s)
Operating System - Microsoft Windows XP Professional
Manufacturer Warranty - 3 years warranty
Dou you think it is good enough for professional video mixing & scratching?
Only question is video card: NVIDIA Quadro FX 1500M - 512 MB, hope it is powerful enough? It is based on nvidia 7900 gs: http://www.notebookcheck.net/NVIDIA-Quadro-FX-1500M.2134.0.html
I already have 1 laptop which should have been good enough but could get rid of clicks and pops....
Weight - 3.4 kg
geposted Sat 26 May 07 @ 4:24 pm
i wouldnt use a laptop with an nvidia card
they take alot of tweaking
geposted Sat 26 May 07 @ 5:39 pm
Should be good for video mixing, only problem can be the drivers if they are well written for this video card. If it is like 7900Gs, than it is ok.
geposted Sat 26 May 07 @ 7:23 pm
sky's right .....if that xp professional turns out to be media center edition ......mce is a variant of xp professional
that unit is loaded up with all kinds slop you don't need,
you already had one you couldn't get rid of clicks and pops........did you read norway's set up guide ??
you are gonna have to tweak it out a lot ......
geposted Sun 27 May 07 @ 11:07 am
Question for you skyfxl:
You mention these types of laptops need a lot of "tweaking". I own this exact same laptop and I run VDJ on it very well. I really haven't done any tweaking and use the HP branded nvidia drivers.
This laptop is a business class laptop with XP Professional. The nice thing about business class laptops (over consumer/personal ones) is the fact that you get minimal "slop" when it comes to pre-installed programs. But I did a fresh XP install anyways so that's not an issue.
I read some articles on here that say you need to "tweak" these NVIDIA laptops. I made some simple changes to performance and such. But if you can elaborate more on what needs to be "tweaked" it may help me run even better.
The one downside to this laptop is... I have to run with the HP branded drivers because if I use third party drivers I lose the ability to adjust the brightness on my screen (stupid HP proprietary crap).
geposted Tue 12 Jun 07 @ 5:03 pm
