Hi Guys,
I just got my new MK2 an as I'm going to Australia soon I don't have room for mixer in my bag! I do have room for my MK2 and laptop though! I just changed all my settings in VDJ to use the MK2 as the soundcard, no TC inputs and 1 output to go to the PA just to see what it was like and I can only get the sound of whatever is coming through the PA in the headphones regardless to what I do with the headphone settings on the MK2 (Deck A, Deck B, Mix and Split). In mix I get whats coming through the PA an in split I get it in one ear ( as it should), nothing with deck a or deck b though!
Any Ideas?
Rory.
Any Ideas?
Rory.
geposted Sun 27 May 07 @ 5:07 pm
choose
inputs : none
outputs: headphones
card: mk2
channels 1/2 main 3/4 heapdhones
plug the amp into 1/2 outputs.
inputs : none
outputs: headphones
card: mk2
geposted Sun 27 May 07 @ 5:11 pm
If you're using an external mapper, select the Mk2 as "4.1 soundcard": "Front channel" for the main output, and "Center channel" for the headphones. Plug the main output to output 1/2 and the headphones to the Phones connector, or Output 3/4 (but they won't work with A or B PFL if I remember well).
geposted Sun 27 May 07 @ 8:37 pm
Thanks Guys. Sorted.
Rory
Rory
geposted Sun 27 May 07 @ 10:06 pm
